4Manny
#1 Posted : Monday, October 12, 2009 8:27:21 AM(UTC)
4Manny
Original shatterd and I ordered the replacement piece of glass. Instead of replacement double stick tape, there are three pieces of adhesive aluminum foil - two rectangles, approx. 4" x 5", and one strip, the length of the glass and about 1.5" wide. How do I attach (outer) glass to door frame? Looks like what I realy need is some type of heavy duty adhesive to use on the top corners of glass and door frame...
protobobby7
#2 Posted : Friday, August 13, 2010 5:09:01 PM(UTC)
protobobby7
i HAVE THE SAME SITUATION AND DO NOT KNOW WHERE THE FOIL IS SUPPOSED TO BE LOCATED. THE ORIGINAL EXPLODED SO THERE IS NO WAY OF FIGURING IT OUT FROM THE CHIPS OF GLASS ON THE FLOOR.:cool:
