Bigking97
#1 Posted : Saturday, October 26, 2013 12:57:57 AM(UTC)
Bigking97
I recently found out my water pump was not working. After getting a new part, it was still not working.
I joined the wires directly to the pump and it still did not spin.
Have I lost the power to the pump from the circuit board?
Is there any other factors that has to happen before the pump will spin? The way I was testing it was by manually pressing the micro switch on 'extra dry' mode during a spin.
Everything else works fine
#2 Posted : Saturday, October 26, 2013 2:29:55 AM(UTC)
Beko looks like a UK unit.
A model number may help others help you.
I probably will not be able to find any technical data on it.
This site deals mostly with North American units so I do not know where to find other tech data.
[COLOR="Blue"]I joined the wires directly to the pump and it still did not spin.[/COLOR]
Not sure what wires you are referring to.
Without a wiring diagram I cannot comment.
Check the pump winding with a meter to see if there is continuity.
You could also usea cheater cord to hook it directly to power butagain I am not sure what power this pump requires so a direct hook up may blow it.
[COLOR="Blue"]Have I lost the power to the pump from the circuit board?
Is there any other factors that has to happen before the pump will spin?[/COLOR]
Sorry but again cannot comment.
