WillyJ232
#1 Posted : Thursday, October 24, 2013 6:21:55 PM(UTC)
WillyJ232
Hi, My GE Profile has a problem I haven't seen listed yet. Everything works fine except the dispenser light that usually dims after dispensing water or ice is now always on. All the green LED's are lit and all the buttons work, except the light will not turn off, even after holding the light button. Tried swapping main control board with another and same problem. Could this be a bad dispenser panel/board? I would appreciate any advice. Thanks
