cindisue2
#1 Posted : Thursday, October 24, 2013 1:10:21 PM(UTC)
cindisue2
I have to stand around to manually change washer cycles. Which part of the timer would need fixed? :confused:
#2 Posted : Saturday, October 26, 2013 2:43:13 AM(UTC)
Parts for GLWS1233S - AppliancePartsPros.com
If you are confident that it is the timer then the timer needs replacing.
Individual timer parts are not available.
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
GE dryer timer issue (Dryer Repair)
by Guest 5/8/2024 11:47:16 AM(UTC)
Whirlpool ler5635lq0 timer issue (Dryer Repair)
by Rolandtd 3/26/2024 6:15:44 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Hotpoint timer stalls in middle of opperation (Dishwasher Repair)
by Fidofax 2/15/2024 8:50:49 AM(UTC)
Dryer won’t stop after timer ends (Dryer Repair)
by ittssarah 2/4/2024 9:04:33 PM(UTC)
Kenmore 592-89032 Dryer POWERS OFF mid-cycle on both timer and moisture settings (Dryer Repair)
by Guest 7/15/2023 6:11:04 AM(UTC)
Alternate timer control for older Maytag top load washer ModelLAT8210AAW (Washer Repair)
by Guest 7/7/2023 12:43:57 PM(UTC)
Is the timer bad? (Dryer Repair)
by FatnSlo 5/1/2023 1:35:57 PM(UTC)
Dryer Timer Humming (Dryer Repair)
by terzolino 4/6/2023 10:18:16 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
GE Profile Range Timer Button Not Working (Oven Repair (including Ranges and Cooktops))
by Bush444 11/23/2022 10:11:35 AM(UTC)
PAVT910AWW Maytag no spin (agitates instead), no refill, no rinse, timer stops. (Washer Repair)
by owkaye 7/27/2022 5:04:45 AM(UTC)
Older Maytag top load “timer” (Washer Repair)
by CP1 6/4/2022 3:58:19 PM(UTC)
GCRG3060AFC Frigidaire Gas Range Timer & Temp Display Error (Oven Repair (including Ranges and Cooktops))
by ChuckCastiglione 8/22/2021 7:09:15 PM(UTC)
