Groups ready for retrieval: Registered
Hello" I'm looking for someone to help me narrow my problem down from replacing the control board, or replacing the mixing valve? when you turn unit on and it starts to fill, It shuts down momentarily. question on eliminating the control board? If there is a restriction in incoming water supply , screens clogged in hoses or settlement build up in valve itself. Is it possible to receive an f1 fault code reading for this problem as well. And would you suggest changing it out if you can hear that the solenoid just doesn't sound right ? Or replace the control board :confused: ? Your immediate response and assistance is appreciated..
