My frigidaire gallery freezer model number glfc1526fw5 runs and keeps things frozen but it gets to cold about 15 below and then gets up to 10 above before coming on. I have replaced the temp control thermostat and the condenser on back of the starter and it hasn't helped, wondering if the starter is the next steps or what else to check.
I was wondering if the thermostat could stilll be bad, or if the tube the temp probe goes in could somehow be the problem.
My next guess was the starter relay could thus be the problem?
