Rank:: Member
Flashing codes 5E and 22E on display panel, still working fine. Can you tell me what parts I need to fix it,
I cannot say what is causing the error codes. This is a complex piece of of gear and it is probably best to leave it to a pro. Though it is best to try and find one who has actual experience repairing these units. Below ia a link to a tech sheet which may help you diagnose the problem. You will have to join the site to be able to download the sheet. http://appliancejunk.com...wnloads;sa=view;down=349 |
THIS FORUM IS DEAD!!!!!!! |
