kenmore bottom freezer-freezer not freezing , refrig stays 48 -compressor runs and does shut off
Check the freezer temperature. It should be between 0 and 5 degrees F.
It is probably higher.
Your problem could be a the evaporator/freezer fan or a defrost problem or a sealed system problem.
Check that the evaporator fan is running and blowing air.
You will have to check the evaporator/freezer coils.
If they are heavily iced/frosted over you have a defrost problem.
If there is no frost or only frost in one area (usually where he freon enters the coils) then it is a sealed system problem. This will be an expensive repair as you need a pro. Often it makes more sense to put the dollars towards a new unit. Check your warranty as the sealed system has a longer warranty on some units. |
THIS FORUM IS DEAD!!!!!!! |
