Originally Posted by: richappy Check that your light bulbs go off when you close the door. Yes they do, but they are totally blowing out, is a power surge possible?
No, but intermittent connections will blow the bulbs, check the sockets.
Originally Posted by: solw Yes they do, but they are totally blowing out, is a power surge possible? OK, thought it might have something to do with the freezing problem, probably just a symptom
Try spraying the cold control with a non-residue contact cleaner available at wall mart, just spray the outside all over while exercising the control, just might fix it, I just hade one the other day I fixed
Originally Posted by: richappy Try spraying the cold control with a non-residue contact cleaner available at wall mart, just spray the outside all over while exercising the control, just might fix it, I just hade one the other day I fixed Is that located inside the refrigerator, where the light bulb is?
In back of the control panel where the knob is to control fridg. temperature.
