The dryer came with 120v cord. I have a 220 volt outlet. I need to convert this dryer if possible. There is an small access plate but I do not see how to attached the 240 cord. Thank you. :confused:
It is not possible.
The heating coil is for 120 volts. The unit should be hooked up to a dedicated 120 volt circuit. |
THIS FORUM IS DEAD!!!!!!! |
