susanwi1238
#1 Posted : Thursday, October 17, 2013 5:29:46 PM(UTC)
susanwi1238
all of a sudden my oven digital controls are not visible, I have power because the light in oven is on, may be stuck in Sabbath mode, can anyone help me with this
#2 Posted : Friday, October 18, 2013 1:54:48 AM(UTC)
Parts for Whirlpool GBD307PDT7 Wall Oven - AppliancePartsPros.com
If the unit is in Sabbath/locked mode there should be an indication of this on the control/timer.
Here is the operators manual.
http://www.whirlpool.com/digita...0Guide%20-%208300609.pdf
Have you tried shutting power off to the unit for a coiuple minutes to see if it will reset?
If the display is totally off then it could be that the thermal fuse in the line to the control boards power supply is blown.
If the above is not the case then I need more info on exactly what is happening/symptoms.
File Attachment(s):
GBD307.pdf (420kb) downloaded 1 time(s).
