Hello Everyone! My dishwasher leaks on all of the rinse cycles (not the draining cycles). I took the thing apart and I noticed that it was leaking from the thing that I attached a photo of. The part is located on the right side of the outside of the dishwasher when I pulled it out. There is not a leak in the hose (the leak comes from both sides of the white thing). When it leaks, it is a very steady stream. I would rather try fixing it myself if possible.... Can anyone help? Thanks :)
The dishwasher is a Whirlpool.
Thanks!
