Shadowraven
#1 Posted : Friday, October 11, 2013 9:08:35 AM(UTC)
Shadowraven
Sears Kenmore Series 70 Washer
Model Number: 110.26712693
Manufacturer: Whirlpool (I believe)
I am working on repairing a friend's washer that will not fill with water. When started it does not even attempt to fill, but goes straight into agitation. The unit empties without problem, but won't fill. Currently my friend is using a garden hose from outside to fill his washer. He contacted me because I am usually able to fix anything that breaks, but I am always still learning.
This washer may be older than 10 years but still works very well and I see no other problems with it. He is committed to keeping it for now.
I believe that I have already located the problem but would like some confirmation before I order a $53 part for him. I think that the problem is being caused by a faulty Water Level Switch and that this: Water Level Switch, is the part I need to fix it.
I have already disassembled the washer and checked the line, it is clear and unobstructed. I've checked the water lines and they have pressure. He also reported that he had to jiggle the water level dial to get it to work just before it stopped filling. I don't think that the problem lies with the fill valves as the washer doesn't even attempt to fill itself. It just goes straight into agitation. I would be very grateful if one of you experts could chime in here and confirm my suspicions.
Thanks guys!
fairbank56
#2 Posted : Friday, October 11, 2013 9:50:52 AM(UTC)
fairbank56
Groups: Expert
Pressure switch could be the problem. Check with multimeter with empty tub. Disconnect wires from switch and check for continuity between where the violet wire and pink wire were connected. Should be 0 ohms (short) and open between violet and tan connections. If there is continuity between violet and tan terminals on switch, disconnect pressure hose and check again. If you still have continuity, switch is faulty. Jump violet and pink wires together to see if washer will fill.
Whirlpool W10337780 Water Level Switch Kit - AppliancePartsPros.com
Eric
carpinteyrorli
#3 Posted : Saturday, October 12, 2013 12:54:21 AM(UTC)
carpinteyrorli
cheap belstaff In many respects, your chosen waterway will assist identify the basic related equipment listing. Many kayaks developed for stumbling and / or traveling provide you with discussed storeroom each of those fore not to mention aft belonging to the cabin. Such opportunities will be rather small-scale.
Mulberry Sacs babysitterofnalts is actually the compassionate taker. please be sure to to help you meet the regards. your lady in no way damages me personally and he or she request to cooking that will distinct. Overcom Only two massive egg on yet another carrier toilet bowl; period through pepper and salt. Incorporate tuckered out matzo; combine unless joined along with humid hitter types. Temperature Two tablespoons vegetable oil and gas within the significant frying pan throughout mediumhigh temperatures.
North Face uscita Privacy may also be a major problem for many individuals. The vast majority of international locations ordinarily part of overseas opportunities need laws and regulations causing it to be unlawful with the expenditure firms to secrete any specific specifics about their own buyers. You will find there's without any governments canceling.
belstaff jackets The latest modernization of data technology has drastically infected the actual lifestyles of consumers internationally. On top of the current online assistance, it offers effectively designed the planet seem to be reduced considering that it represents an essential part in almost every people's life, as a result of home shopping to help amassing information and facts. The traditional ways of looking for a personal ended up being a hardcore and also time consuming task.
