Freezer/frig. will not cool. There was no continuity on Defrost thermostat nor the defrost control timer so I replaced both. Installed both but still no cooling. Compressor comes on but there is no cool air in the freezer compartment even after rotating the newly replaced defrost control timer out of defrost cycle. What else should I look for or check???
