My Jenn Air fridge stopped working on me and i'm at a loss on what the problem is. The fan works and the compressor seems to be working. The compressor has a very mild vibration when you put your hand on it and gets a little warm to the touch. I did the resistance test with a multi meter on it and I believe it passed (if I did it properly of course). I bought a new overload relay from here hoping that would be an easy fix but still the same story.
Where do I look next? The curious thing I noticed is the air coming out of the fan seems to be cool and thought that was supposed to be a little warm.
Anyone have any ideas for me? It would be GREATLY appreciated!!!
If you have a meter, check the voltage to the compressor, might be low due to a burnt wire.
