garlmiller1965
#1 Posted : Tuesday, October 8, 2013 3:57:48 AM(UTC)
garlmiller1965
condenser fan motor runs but i an not getting no voltage to compressor
#2 Posted : Tuesday, October 8, 2013 4:41:06 AM(UTC)
Most probably a bad motherboard in the back. To confirm unplug 3 pin power connector and place a wire jumper between the mating pins labeld "line and comp." printed on the board, then plug in compressor: should run.
compressor wont run (Heating, Ventilation, and Air Conditioning (HVAC))
by bryanb1964 5/7/2013 5:27:01 PM(UTC)
