I have a Kenmore gas dryer (110.70602990) that is not working in either Auto Dry setting (High or low heat), but works fine in timed dry. When using Auto Dry, the drum spins, and blows air, but it doesn't heat up and the timer dial does not spin. I tried out timed dry, and it gets hot and the timer spins. Any help would be appreciated. By the way, I do have my parts list, but not a wiring diagram. Thanks.
Hi - I have an update, and I wanted to bump this up.
I have found that that timed dry doesn't work now. The time will count-down, but the heat doesn't kick on. It worked the other day, so I'm not sure if that was a fluke, or the heat is intermittant. I am wondering if I should replace the burner or if it is something else.
Again, any help would be appreciated.
Thanks.
