There is a code F7 and constant beeping how do I get the code off and the beeping stopped!
This is a very common problem with GE Ranges contact Ge in regards to your happines with their products. Even after replacing the expensive parts necessary it usually breaks down with a year after that because of the cheaply made parts being defective as well. Just google search GE oven f7 code you'll see a million complaints call GE directly and see if they'll remedy there big mess up. http://www.geappliances.com/service_and_support/contact/
F7 Stuck Button
1. Function pad button stuck or 2. Bad clock. Try to free stuck button or 3. Replace Electronic Range Control (ERC).
