yesboss1
#1 Posted : Monday, September 30, 2013 7:36:12 AM(UTC)
yesboss1
hi, my 8 year old whirlpool du945pwpq0 dish washer stopped working. no light at control panel. i checked door switch , thernal fuse they both ok in terms of continuity and 120 ac. i replaced control panel still no light , i am returning control panel and will try control board . what could be probelm ? need help.
Gunter
#2 Posted : Thursday, December 12, 2013 7:09:56 PM(UTC)
Gunter
I had the same issue with my whirlpool, no lights and would not start. To correct this I just slightly bent the metal bracket(top center) which activates the door switch. This corrected the issue for me. Hope it helps you too.
