drwibble
#1 Posted : Sunday, October 11, 2009 1:59:51 AM(UTC)
drwibble
*apologies - wrong forum - will copy it over - mods please delete - thanks*
Hi
My samsung washer will turn on when I press power but then it appears that all the buttons are frozen including the power button - the only way in which I can turn it off is to switch it off at the wall.
Any suggestions gratefully received - is it a simple problem or does it require a new control panel? if so, am I better getting a new machine?
Many Thanks
samsung washer control panel (Washer Repair)
by drwibble 10/11/2009 2:02:43 AM(UTC)
