Ran the oven in the self cleaning mode, now it is stuck in the cleaning mode. The light flashes on clean mode. I have tried to rest it by unplugging the stove. That has not helped. I am thinking control board. Is there anyone smarter than me?:eek::cool::eek::cool:
NEVER USE THE SELF CLEAN THEY FRY YOUR OVEN. In most cases it ruins the door lock circuit giving you a code. Check to make sure your door lock circuit is ok...........Check all your connections at the main board and make sure you don't have any burnt wiring harness. And it's usually one of two things the main board or the door lock in most cases.
