Fred Enright
#1 Posted : 11 years ago
Fred Enright
Hi My oven takes up to 40 minutes to ignite. The ignighter is bright orang but no gas seems to be getting through. I have tried manually ignighting with no success. any clues Thanks Fred
HumboldtRepairMan
#2 Posted : 11 years ago
HumboldtRepairMan
Just because the ignitor glows it doesn't mean it's good......The ignitor must be pulling 3 amps or more before the safety valve will release. IF the ignitor is ashy or white in color replace it or test the Ac amp pull and if your under 3 amps it's bad.
Kenmore gas oven not lighting (Oven Repair (including Ranges and Cooktops))
by wingmaster12 12 years ago
PLEASE? Frigidaire Gas Oven Not Lighting? (Oven Repair (including Ranges and Cooktops))
by mikk 15 years ago
