igneous
#1 Posted : Monday, September 23, 2013 2:13:07 PM(UTC)
igneous
The front left burner on my kenmore glasstop is only half working. There is only a switch for the heat, and then a button for simmer select. When I turn it on high the outer 50% turns read, but the middle part is clearly not turning on. I haven't pulled anything apart yet, just trying to figure out if its possible a simple fix.
igneous
#2 Posted : Tuesday, September 24, 2013 7:27:23 PM(UTC)
igneous
UserPostedImage
this is what it looks like on high, before the entire middle part would be red, now you can clearly see part of the burner isn't on
#3 Posted : Wednesday, September 25, 2013 2:45:01 AM(UTC)
It could be the element itself or the infinite switch.
A model number would be helpful.
Find your model number - AppliancePartsPros.com
I may then be able to find a wiring diagram that could make it easier for you to measure the heating coils in the element.
If they check out OK for continuity the I would replace the infinit switch.
