rkschwer
#1 Posted : Monday, September 23, 2013 6:37:25 AM(UTC)
rkschwer
My dryer is making this awful banking/ thumping noise. The belt was changed a couple years ago, but from what I can tell the drum seems to turn when I push power, so its not that, I dont think..could it be the motor?? or something loose?
Thank you
Rebecca
#2 Posted : Tuesday, September 24, 2013 1:30:12 AM(UTC)
Parts for Maytag SDG4606AWW Dryer - AppliancePartsPros.com
Often thumping is due to a bad rear drum support roller.
Also check the seam on the drum. Sometimes they can crack/split along the seam.
