Rico Whiskey Delta
#1 Posted : Saturday, September 21, 2013 10:10:40 AM(UTC)
Rico Whiskey Delta
Hello everyone
I`m trying to repair my mother`s GE washing machine. The problem according to her is that the drum itself does not spin during operation. From what she has told me the motor runs and the machine drains fine, but she does not know if the agitator is working correctly.
She had washed a sofa cover with the cushion covers as well(maybe too big of a load?) and had put a load of towels in and that's when she noticed the drum wasn`t spinning. I have pulled the front cover off and inspected the drive belt which was my first culprit but everything inside this machine looks brand new. Its only a little over 3 years old.
The pulleys do not seem locked up but the bottom part of the agitator only turned slightly with great resistance until it did lock up. Ive got the front cover off and my tools out ready to go if anyone might know what I need to look at, until then I`m trying to talk her into some good ole` home cookin`:D
Rico Whiskey Delta
#2 Posted : Saturday, September 21, 2013 10:11:37 AM(UTC)
Rico Whiskey Delta
Originally Posted by: Rico Whiskey Delta Go to Quoted Post
Hello everyone
Serial # is LV149979G
fairbank56
#3 Posted : Saturday, September 21, 2013 11:00:38 AM(UTC)
fairbank56
Groups: Expert
Put it in spin mode. Does the motor pulley, belt and main drive pulley rotate? Does the transmission rotate?
Eric
Rico Whiskey Delta
#4 Posted : Saturday, September 21, 2013 1:04:40 PM(UTC)
Rico Whiskey Delta
Eric
Thanks for the reply. I have the water supply disconnected at the moment, would the pump be damage if I do put in spin cycle without water supply and drain connected?
fairbank56
#5 Posted : Saturday, September 21, 2013 1:06:27 PM(UTC)
fairbank56
Groups: Expert
No, doesn't matter.
GE washer will not spin (Washer Repair)
by MS104 5/10/2016 4:34:48 PM(UTC)
GE washer will not spin with heavy load (Washer Repair)
by carpe 11/2/2013 3:08:18 PM(UTC)
GE washer will not spin or agitate (Washer Repair)
by tarzandude43 12/18/2012 9:05:54 PM(UTC)
Ge washer will not spin or agitate (Washer Repair)
by Paul Di 3/25/2011 3:02:25 PM(UTC)
GE Washer will not spin (Washer Repair)
by mazdaboss 8/18/2010 6:56:42 AM(UTC)
GE Washer will not spin on heavy loads (Washer Repair)
by hmorton 5/11/2010 10:29:14 AM(UTC)
by tcpr12 3/6/2010 6:35:34 PM(UTC)
by bfreeman91080 1/13/2010 9:15:50 AM(UTC)
GE Washer will not spin or agitate (Washer Repair)
by casshley 11/6/2009 6:00:06 AM(UTC)
by tcahapw 6/19/2009 7:38:23 PM(UTC)
GE washer will not spin nor agitate (Washer Repair)
by Evans 5/18/2009 1:45:06 PM(UTC)
ge washer will not spin or agitate (Dishwasher Repair)
by m-fuson 3/8/2009 9:44:10 AM(UTC)
GE Washer will not spin on rinse cycle (Washer Repair)
by mguy77 1/15/2008 3:14:22 PM(UTC)
by csol147462 11/1/2007 7:37:16 AM(UTC)
