I open the freezer and close the freg open or vive vercre open the freg the freezer open.What wrong?? sonnyshop@live.com
This is normal to a certain extent, when you open the refrigerator door warm air fills the cabinet. Then when you close the door you force the air through the air ducts and it forces the other door open. However the door shouldn’t open but an inch or two and close back on its own. You can try adjusting the front of the refrigerator up so that the doors will have a tendency to swing closed better. Also the cams on the bottom of the door may be broken. These are the parts I am talking about http://www.appliancepartspros.com/part_details.aspx?part_id=4247867 Hope this helps Refrigerator Door Repair Guide
