I have a Whirlpool fridge with a bottom mount freezer. Model eb9fvhrws01.
The drain tube that allows water to flow after the defrost, from the evaporator coils...is clogged.
Is there a rubber grommet at the end of the defrost tube that I could remove and try to clear.
If yes...how do I access this. I have opened up back of fridge and do not see any tube. Not sure where to look on this model.
