I just finished replacing the bellow and now the control locked light is lit. is there a reset so something that will reset the control panel? any help would be grteful
You can unplug it and wait for several hours to see if that unlocks it. If you take off the bottom panel you should find tech notes for trouble shooting, but if the console is locked you may not be able to put it in test mode. Here is the service manual which may also help. https://secured.whirlpoo...ILE/Duet%20Job%20Aid.pdfGood luck
