871david
#1 Posted : Monday, September 16, 2013 11:33:08 PM(UTC)
871david
Good morning, my fridge freezer never stops running. The temp. is correct in both compartments. Help please. Thanks, David
#2 Posted : Tuesday, September 17, 2013 3:21:51 AM(UTC)
I cannot find any info on the given model number.
Please check it.
Find your model number - AppliancePartsPros.com
If this is a non USA model tech info may not be available to us.
Also it depends on the brand.
Some modern units never shut the compressor off. They use a an inverter and vary the compressor speed.
If this is a more common type of compressor:
Check that the condenser coils under the unit are clean.
Check that the condenser/compressor fan is on.
Check the door seals.
Check that the vents in the kick plate and rear cover are clean.
Check the freezer temperature. It should be 0 to 5 degrees F.
871david
#3 Posted : Tuesday, September 17, 2013 4:38:31 AM(UTC)
871david
Thanks, will check this out, David
