abbadog
#1 Posted : Monday, September 16, 2013 7:38:53 PM(UTC)
abbadog
I used the 'cook time" setting on my built in oven and all worked successfully.
When i tried to use the oven again i noticed that the clock number display had changed from a large numbered central one to a small upper screen display.
When i tried to turn the oven on a few hours later the click of the dial to "bake" or any other setting elicited no response. The clock is working the interior light works but the oven settings remain asleep. Suggestions?
HumboldtRepairMan
#2 Posted : Tuesday, September 17, 2013 4:09:02 PM(UTC)
HumboldtRepairMan
Check to make sure you have 120v going to the touchpad/main control piece if you do and it's not working then you need a new electronic timer on the link below.
Parts for HBL54 - AppliancePartsPros.com
Clock & Oven controls not working (Oven Repair (including Ranges and Cooktops))
by wfcoleman 1/2/2017 2:51:37 PM(UTC)
Oven Controls not working (Oven Repair (including Ranges and Cooktops))
by BrianGas 2/21/2014 10:04:31 AM(UTC)
