AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Maytag Neptune Washer no on light or door locked light
Hello, my name is Ken Im working on a Maytag Neptune MLG2000AWW. The washing machine is the problem. First of all the ON LIGHT wont come on altho the machine starts filling The DOOR LOCK LIGHT does not come on. If I keep the START button pushed in the machine continues to fill and agitate then drain but it will not spin. It does not pump out all the water in the tub but water is not visible in the tub, you can hear it slosh around when tub is rotated. Ive tried replacing the TIMER, no luck. Ive tried replacing the MOTOR CONTROL BOARD, no luck. Does this machine have a PUMP FILTER? Can the DOOR LATCH MECHANISM be checked. Any help will be greatly appreciated. Ken Read more: http://forum.appliancepartspros...ycles.html#ixzz2f1erP83x http://forum.appliancepartspros.com
Washer Repair
