The ice dispenser on the door does not dispense ice. The ice holder has plenty of ice. When trying to dispense ice, the motor will turn if i push down on the ice holder. The gears between the ice holder and the motor gear appear to be slipping. The gears dont appear to be worn out. Should i replace the motor and gears?
:confused: Originally Posted by: timwilburn  The ice dispenser on the door does not dispense ice. The ice holder has plenty of ice. When trying to dispense ice, the motor will turn if i push down on the ice holder. The gears between the ice holder and the motor gear appear to be slipping. The gears dont appear to be worn out. Should i replace the motor and gears?
