kimbray
#1 Posted : Saturday, September 14, 2013 9:15:08 AM(UTC)
kimbray
JVM2070SK02 Model number
Here is my issue and trying to determine what will fix it and if getting a new microwave is the best course of action.
With the unit power removed and then re-plugged in, the touch panel comes on and everything is fine (solid panel screen). If you DO NOT open the door, it will heat something that is already in the unit and you can open door and all is good to get heated item.
When you go and shut the door, the control panel flickers and the exhaust fan starts going and the light in the microwave flickers. Also the tray table starts to rotate. Like it things it is on...
I think it has to do with the door sensor/lock mechanism for the microwave, but looking for some guidance. Part 95 or 96 on your schematic...
Any help appreciated!
kimbray
#2 Posted : Saturday, September 14, 2013 11:11:40 AM(UTC)
kimbray
Opened unit up. Determined that one of the door sensor connectors was loose. Put back together again and control panel and light do not flicker now, BUT when I run the microwave, the timer counts down but power does not come on to heat and the table does not turn. I think on the center door sensor, there is a power connection piece that I think I messed up. any help appreciated.
