kajjc
#1 Posted : Friday, September 13, 2013 1:15:30 PM(UTC)
kajjc
My washer will not go through the rinse cycle. It runs normal through the wash cycle and stops before draining/rinsing. There is a faint buzzing sound coming from the timer when it is supposed to be rinsing. I can advance the knob through the rinse cycle to the spin cycle and it works fine (drains/spins).
It fills normally with warm or cold so I don't think a stopped inlet is the problem.
Checked the lid switch and it is fine as well.
Anything else I should check? Does the timer need to be replaced completely or can it be reset? Timer #3953321A.
Thanks much!
fairbank56
#2 Posted : Friday, September 13, 2013 2:45:21 PM(UTC)
fairbank56
Groups: Expert
Need the model number of the washer.
Eric
kajjc
#3 Posted : Friday, September 13, 2013 3:54:46 PM(UTC)
kajjc
Model #
LSQ8543J20
fairbank56
#4 Posted : Friday, September 13, 2013 6:28:26 PM(UTC)
fairbank56
Groups: Expert
Assume you meant JQ0, not J20? Need to replace the timer.
Whirlpool 3953321 Timer - AppliancePartsPros.com
Eric
