How do I replace the lint housing unit on my GE Quality Product Spacemaker Laundry unit? WSM2400LBBWH
Originally Posted by: HumboldtRepairMan ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Does the front panel of the dryer come off to expose the lint housing?
You don't have to remove anything from the front the lint trap housing should just pull straight up....there' may be 2 wires to the moisture bars that's it just disconnect them if necessary and reattach to new piece
Originally Posted by: HumboldtRepairMan ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) You don't have to remove anything from the front the lint trap housing should just pull straight up....there' may be 2 wires to the moisture bars that's it just disconnect them if necessary and reattach to new piece The replacement piece is too big to get through the dryer opening. Part #we14x196
