The difference between cause and correlation sometimes stumps me. My Bosch is running but no water is coming into it. Tonight I'll open it up and test the water inlet valve and, if I can find it, the float switch.
But I'm wondering if something else is going on here. Two days ago I turned off the main water inlet to the house while I replaced the kitchen faucet cartridge. I think this problem began after that. The water valve under the sink that feeds the dishwasher is open. Any thoughts?
Dirt/debris or rust probably got caught up in the water inlet valve screens possibly.....check that first. Check to see if you turned off any valves under sink to it also.
