jharmon
#1 Posted : Tuesday, September 10, 2013 1:12:51 PM(UTC)
jharmon
I have a maytag dryer (model MEDC400VW0) that fails to dry the clothes on the first load. Sometimes it takes two or three loads. I had a technician come out when it was under warranty and he said that the temperature sensor were working fine. But it used to dry in one load and now it doesn't.
#2 Posted : Tuesday, September 10, 2013 2:01:10 PM(UTC)
The most common cause of this is the vent system.
Unplug the unit and disconnect it from the vent system.
Now try a run.
If it now dries OK odds are the vent system needs checking/cleaning.
Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house.
Take a pair of pantyhose.
Put one leg into the other and then attach this to the dryer's vent.
Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the temperature and the air flow.
Note: The above is not recommended for gas dryers due to carbon monoxide concerns.
