cw73
#1 Posted : Tuesday, September 10, 2013 11:46:55 AM(UTC)
cw73
I have a Maytag Neptune with a moldy boot. I have followed ALL of the recommended cleaning methods to get rid of the mold and the moldy smell. At this point I figure this part needs to be replaced. My concern is should I replace the hose clamp and little drain pieces while I'm at it? Parts 21-23 on the diagram (I think).
Also, is there a way to clean the filter? on the plastic part behind the boot (cover,tub seal). It appears to be a lint screen that runs about the bottom third of the tub.
I now know to keep the door open when not using my washer, but the damage is long since done.
HumboldtRepairMan
#2 Posted : Tuesday, September 10, 2013 5:21:30 PM(UTC)
HumboldtRepairMan
When replacing the boot you need to replace the rear clamp or spring and the front spring as well i always do otherwise you come home to a boot falling off and a flood in your house sometimes...........Here's a video to help....i tried looking at the schematics for the unit for part numbers for you but this schematic sucks sorry.
maytag boot replacement - YouTube
