I HAVE FRIGEDAIRE REFRIGERATOR LESS THAN 2 YEARS OLD.OVER LOAD RELAY BURN OUT AND I TRY WITH HARD STARTER BUT ONLY FAN WORKING AND NO COOLING.IS IT POSSIBLE THAT COMPRESSOR GONE? HOW TO CHECK THIS PROBLEM?:confused: :mad: CAN ANYONE HELP ME ?
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Below is a good link on how to check the compressor. How To Fix a Refrigerator - Appliance Repair Guide - ACME HOW TO.comI am assuming that there is no cooling at all in the freezer. Is the compressor vibrating? If yes then it is on but you probably have a sealed system problem. Testing the windings can tell you if you have a blown compressor. It does not tell you that the compressor is OK as it may have internal mechanical problems etc. |
THIS FORUM IS DEAD!!!!!!! |
