fjerstade
#1 Posted : Friday, September 6, 2013 4:49:32 PM(UTC)
fjerstade
Fridge got warm around center divider between freezer and fridge (side by side unit), and no airflow from under unit. Removed lower back access panel, fan not spinning. Placed box fan to blow on condenser, and fridge performance returned to normal. Connector at fan had 14V, so I assumed fan was bad. New fan also doesn't spin, so perhaps fan control is a relay to "ground".
Is a schematic and wiring diagram available for this unit to further troubleshoot?
#2 Posted : Saturday, September 7, 2013 2:29:21 AM(UTC)
Schematic usually behind the encoder in fridg section Schematic will probably not help. Seems like you need to replace the motherboard in the back.
