mickeyd819
#1 Posted : Friday, September 6, 2013 4:02:48 PM(UTC)
mickeyd819
I took the front off the dryer to clean out the dryer vent tube and related parts. When I removed the thermostat cover it fell across one of the cut off T pigtails and the dryer cabinet. Since I had forgotten to unplug the dryer, (I know, two college degrees, much electrical experience, etc.), it arced and melted part of the cover and the Cut Off T slide on connector. After unplugging the dryer and cleaning the parts I needed to clean, I reassembled the dryer, reconnected the Cut Off T, and tried to start it. It does not run. I checked continuity across the Cut Off T and had none. I figure the Cut Off T needs to be replaced. When watching the repair video, it said that the Cut Off T needs to be replaced if the dryer runs and does not heat. Mine won't start. Any suggestions on how to get me up and running again. I learned another valuable lesson today and hope you can help me get my dryer to run. I want to order all the parts needed at the same time. Thanks...
#2 Posted : Saturday, September 7, 2013 3:07:13 AM(UTC)
Parts for Maytag LDE9306ACE - AppliancePartsPros.com
It includes a wiring layout.
Here is a link to a service manual.
It has a wiring diagram.
You will have to join the site to be able to download the manual.
http://appliancejunk.com...ownloads;sa=view;down=53
This dryer is wired differently than most.
The thermal cut-off (thermal fuse - heater) and the thermal fuse (blower) are both wired into the motor circuit.
Could be that the cut-off is your only problem Though I would check the blower fuse just to be sure it is OK.
