The washer won't spin and makes a loud screaching noise, then beeps and blinks F and won't go anymore
F what? Can't help without an F code
It starts to fill then stops , blinks F and then stops , then goes straight to drain , it sometimes spins but now won't even start a load without stopping , how do I do a diagnostic to find out the code? It only blinks F?
Look inside your unit for a tech sheet it'll tell you
In all honesty your best bet is to call in a appliance tech this code is a multiple part check and possibly needing multiple expensive parts and is a pain to diagnose even for techs. Also it's a Duet which when you fix one thing another part needs replacement shortly after and it turns into a serious investment. Good luck
