The draini pumps works all the time does not shut off. The water level switch has been changed as well as the control unit. The water fill works sometimes. Main motor works fine. What could be wrong?.
Give a better description of your problem and scenerios of things happening you're description is all over the place...........Write at least a paragraph of what it's doing and what you've done to test it.
Originally Posted by: HumboldtRepairMan Give a better description of your problem and scenerios of things happening you're description is all over the place...........Write at least a paragraph of what it's doing and what you've done to test it. When the dish washer is turned on the drain pump starts immediately to work,regardless the water level, the inlet valve works fine if it is energized directly,the main motor works, the water level switch has been replaced,as well as the control unit the machine model is shu6805euc/u06'thanks
Most units do begin with a drain mode that's normal but if it doesn't stop then you have a problem most likely with the keypad drain button sticking or the main control. I'd suspect main control more then likely
Originally Posted by: HumboldtRepairMan Most units do begin with a drain mode that's normal but if it doesn't stop then you have a problem most likely with the keypad drain button sticking or the main control. I'd suspect main control more then likely I changed the control module it is brand new
