milli20
#1 Posted : Thursday, September 5, 2013 1:42:47 PM(UTC)
milli20
I have a Maytag front load washer with the following model number: MAH2400AWW. The washer stops spinning after three minutes. It does NOT matter which wash setting it is on. I have taken all of the clothes out, so it is not due to too many items inside. The only thing it does properly is on the drain setting. When it does stop spinning, it makes no sound at all (grinding, buzzing, etc.)
Does anyone have any thoughts on this? Thanks so much!!!
Shutouts10
#2 Posted : Tuesday, October 15, 2013 3:41:27 PM(UTC)
Shutouts10
I have same exact problem with same model, please help!
anitatweedy
#3 Posted : Tuesday, December 10, 2013 9:13:19 AM(UTC)
anitatweedy
mine is doing something similar but getting f 25 code . all we did was change the outer tub barring and we ran it ones to check for leaks and it worked fine. then the next load I washed it would work till time to spin and the code pops up? hoping something may have not got pluged in all the way and vibrated out.
