nkornelis
#1 Posted : Thursday, September 5, 2013 12:41:45 AM(UTC)
nkornelis
I need to test my old door switch, and need to hook it up again. Unfortunately, I didn't pay attention when I unhooked it. Can someone who knows a little about wiring these things let me know which wire goes where? I have a black/red wire (with a plastic clip on the connector), a black wire, a blue/white wire (actually 2 wires to one connector), and a white wire. Based on the length of the wires, I believe that the black/red wire and the black wire go to the red box with the switch (which I believe is the wax motor), and the blue/white wire and the white wire go to what I believe is the solenoid. The solenoid (if that's what it is) has 2 connectors. One is marked 120v, and the other is 60Hz.
There is also a wiring harness with 4 wires, but it is obvious where that goes.
Any help would be greatly appreciated. Thanks.
UserPostedImage
UserPostedImage
UserPostedImage
UserPostedImage
HumboldtRepairMan
#2 Posted : Thursday, September 5, 2013 8:39:14 PM(UTC)
HumboldtRepairMan
The constant 120v hot and nuetral-goes to the wax motor and your open/close switch legs go to the other.
Here's some helpful video's for ya.
https://www.youtube.com/results?...1.11.youtube.MtDZ8zID_Ug
JulesLamers
#3 Posted : Friday, September 6, 2013 1:23:54 AM(UTC)
JulesLamers
I think some of these are damaged..
