snewell917
#1 Posted : Tuesday, September 3, 2013 3:02:47 PM(UTC)
snewell917
Just replaced the high voltage main board and the interior board does not respond at all just flashes PEO 0000. Used program control instructions with no changes at all. Help it does not work!
snewell917
#2 Posted : Tuesday, September 3, 2013 3:07:17 PM(UTC)
snewell917
I am adding that does anyone know if I put the old board back will it have the code in that from previous or would it have the same problem. I would replace because at least it worked with the old board, just stuck in one mode
