Roy Simmons
#1 Posted : Wednesday, February 6, 2008 3:25:30 PM(UTC)
Roy Simmons
I moved the freezer to a place with no air space on either side. The freezer quit. Did I kill it or just injure it? Is there a fix? It was manufactured July 1991. It does not have cooling coils in back, but I would guess in the inside of the sides, and I would guess it got to hot (no space on the sides). If injured, is there a reset button? Thank you for any comments. Roy
#2 Posted : Wednesday, February 6, 2008 5:44:43 PM(UTC)
Hi Roy,
Does it make any noises?
Bypass the cold control and see if the freezer will work.
Post your findings.
Roy Simmons
#3 Posted : Wednesday, February 6, 2008 10:07:07 PM(UTC)
Roy Simmons
The freezer will not run with plugged in. Changing the temp setting does nothing. I really think I killed it. I had thought there might be some reset button or such like. Anyway Gene, thanks for the reply. Roy
