Whirlpool dryer that was running fine 5 days ago. Was moved on its back and now it won't shut off and it ran backwards ???? I see online where it could be the door button all the way up to the timer. Could the transportation of it on its back done this? And what would be the resolve... THanks!
Tell your doctor to change your medication i've never seen that in my life. Maybe if it wasn't working at all that would make sense but i've never seen a machine run backwards. Anytime you turn a drum backwards the belt almost falls off everytime. Check for reverse polarity or bad wiring at the wall receptacle. Did you change the dryer plug at all?
