I have a maytag MGR5765QDB gas range. When I bought it new I converted it to LP. I am now able to switch over to nat. gas and cannot find the orifices that came with the range. I can't seem to find nat. gas orifices on the web, only nat. gas to LP conversions. Does anybody know where I can get the orifices that I need. thanks
Try your local propane dealer they usually have most orfices in all shapes and sizes Or check the back of your unit you may have the original ones taped to the unit for natural that's where they usually put them.
Originally Posted by: HumboldtRepairMan  Try your local propane dealer they usually have most orfices in all shapes and sizes Or check the back of your unit you may have the original ones taped to the unit for natural that's where they usually put them. I converted it myself and applied the sticker. There was a little bag back there and I swore I had put them in that bag. I guess I could hunt the orifices down if I knew the sizes I need for the burners and the oven.
Turn the gas valve off and take them out and with you when replacing at propane place
