Parkhillycarl
#1 Posted : 12 years ago
Parkhillycarl
My profile gas range is about 6 years old. I pulled it out from its place, and cleaned behind it. Then I plugged it in and started to push it back in place. The circuit breaker in the power supply panel box tripped. Now it does that every time I attempt to plug in the unit. Any suggestions as to what I can do before calling a repair man?
HumboldtRepairMan
#2 Posted : 12 years ago
HumboldtRepairMan
Check to see if you pinched the wires on the cord when you pushed it back. Also it could have nothing to do with your range it could be something your sharing that circuit with or something in your wiring in your walls that's overloading the circuit or you could have a bad breaker also. Good luck
